box zooming
Dylan Beaudette
dylan at IICI.NO-IP.ORG
Fri Apr 22 14:13:36 EDT 2005
Steve,
yes, my previous project (where i copied the map file from) was using an image
legend.
i was able to get a working legend after creating a HTML legend template, as
described on the mapserver website. this approach is a little cleaner than
what we had before as well.
thanks for the tips!
Dylan
On Friday 22 April 2005 10:20 am, Steve Lime wrote:
> It does if all you did is copy files. Actually an image legend is
> easier. You just have
> to create an image where the legend div is and update it's src. Try the
> attached script,
> it should be close...
> Steve
> >>> Dylan Beaudette <dylan at iici.no-ip.org> 4/22/2005 10:22:27 AM >>>
> Well... this project is based on a map file where i was using image
> legends...
> Looking at this page on HTML legends, it looks like i should be able to
> cobble something together.
> Just one question, does the DHTML mapserver interface expect an HTML
> legend?
> thanks!
> On Apr 22, 2005, at 7:58 AM, Steve Lime wrote:
> > Gee that looks familiar. Are you trying to use image legends or html
> > legends?
> > Steve
> >>>> Dylan Beaudette <dylan at iici.no-ip.org> 4/21/2005 5:26:59 PM >>>
> > Steve,
> > Thanks for the quick responses. I started a new thread on this
> topic,
> > and
> > included the link to the actual application there.
> > here it is again:
> > http://169.237.35.250/~dylan/mapserver/dhtml/landview_dhtml_x.html
> > thanks!
> > On Thursday 21 April 2005 03:15 pm, Steve Lime wrote:
> >> It would be easier to help if we could see the whole application.
> > Off
> >> the top of my head I would think
> >> there might be a problem with div names, make sure those jive...
> >> Steve
> >>>>> Dylan Beaudette <dylan at IICI.NO-IP.ORG> 4/21/2005 1:51:34 PM >>>
> >> Bart,
> >> Wow! you were right - i was able to fix up my old mapserver
> > application
> >> with
> >> the source fromthe UMN site!!
> >> however, i noticed that my legend does not seem to be rendered.
> >> i modified the source of the UMN page, near the legendURL section;
> >> // update the legend
> >> var legendURL =
> > "http://169.237.35.250/cgi-bin/mapserv?map=/home/dylan/public_html/
> > mapserve
> >> r/mapunit/fresno_w.map&mode=legend&layers=" + ms.getlayerlist('+')
> >> "&mapext=" + ms.extent[0] + "+" +
> >> ms.extent[1] +
> >> "+" + ms.extent[2] + "+" + ms.extent[3] + "&mapsize=" + ms.width
> >> ms.height;
> >> legend.setcontent(legendURL);
> >> i know that the variable 'legendURL' is valid, as it expands to the
> >> working:
> > mapserver
> >> /mapunit/fresno_w.map&mode=legend&layers=&mapext=
> >> -2133333.6828213334+-216382
> >> .321635+-1954777.1482586667+-82464.920713&mapsize=640+480
> >> ... but somehow the legend image is not drawn...
> >> any ideas on this one?
> >> thanks for the help!!
> >> Dylan Beaudette
> >> Soils and Biogeochemistry Graduate Group
> >> University of California at Davis
> >> 530.754.7341
> >> On Thursday 21 April 2005 09:05 am, Bart van den Eijnden wrote:
> >>> Hi Dylan,
> >>> view source is enough (at least it was for me), you can see the
> >> references
> >>> to the various javascript libraries used and download them, also
> > how
> >> to
> >>> use them in the HTML page itself.
> >>> Best regards,
> >>> Bart
> >>> On Thu, 21 Apr 2005 08:58:16 -0700, Dylan Beaudette
> >>> wrote:
> >>>> is there a place to see tis code, or is the HTML source on that
> >> page
> >>>> enough?
> >>>> thanks!
> >>>> On Apr 21, 2005, at 1:37 AM, Bart van den Eijnden wrote:
> >>>>> Have a look at DBox, eg:
> >>>>> http://www.dnr.state.mn.us/maps/landview_dhtml_x.html
> >>>>> Best regards,
> >>>>> Bart
> >>>>> Syncera-ITSolutions
> >>>>> Postbus 270
> >>>>> 2600 AG DELFT
> >>>>> tel.nr.: 015-7512436
> >>>>> email: BEN at Syncera-ITSolutions.nl
> >>>>>>>> Juan Baron <jbarong at HOTMAIL.COM> 04/21/05 10:35am >>>
> >>>>> Hello:
> >>>>> Is possible to do box zooming without applet?
> >>>>> Thank's
> >>>> Dylan Beaudette
> >>>> 530.754.7341
> >>> Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
> > Dylan Beaudette
> > 530.754.7341
> Dylan Beaudette
> 530.754.7341
Dylan Beaudette
530.754.7341
