HPGN Datum?
Bill Binko
bill at BINKO.NET
Sun Apr 24 23:25:13 EDT 2005
Hi everyone,
I found an excellent site for Florida map data:
http://www.fgdl.org/
Some of their data is a bit out of date, but there is a nice selection,
and it's all in the same projection, even from a wide variety of sources.
My problem is that they use a datum that I haven't seen before "HPGN".
Here is the projection info from their metadata:
MAP PROJECTION PARAMETERS:
Projection ALBERS
Units METERS
Datum HPGN
Spheroid GRS1980
1st standard parallel 24 0 0.000
2nd standard parallel 31 30 0.000
Central meridian -84 0 0.000
Latitude of projection's origin 24 0 0.000
False easting (meters) 400000.00000
False northing (meters) 0.00000
After some looking around, and some advice from the board a few weeks ago,
I used these projection instructions in Mapserver (CVS Head):
PROJECTION
"+proj=aea"
"+lat_1=24"
"+lat_2=31.5"
"+lat_0=24"
"+lon_0=-84"
"+x_0=400000"
"+y_0=0"
"+ellps=GRS80"
"+datum=NAD83"
"+units=m"
"+no_defs"
END
It seemed the "NAD83" was close enough to the "HPGN" datam. Now I'm
seeing small problem when combining any of the data from this source with
others that are in the Florida West projection (espg:26759), and I'm
suspecting that the bad datum is the problem.
Actually, I'm hoping that's it because if it is, I'm confident someone
here can help me get it right: if not, it means the data's bad :-(
An example of the "wrongness" can be seen at:
http://www.binko.net/badProj.png
The roads should line up within the parcels. The roads are in HPGN, and
the parcels are in espg:26759
Any help would as always be appreciated.
Bill
PS: Paul R: you did say you loved projection problems, right? :-b
