Perl Mapscript 4.4 Issues
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Mon Apr 25 08:42:26 EDT 2005
Oops, My bad!
The machine I was working on needs to be upgraded. It had an old version
loaded:
MapServer version 4.0 OUTPUT=PNG OUTPUT=WBMP SUPPORTS=PROJ
SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT INPUT=EPPL7
INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
Sorry,
-Steve W.
Lowell Filak wrote:
> The following message was sent by Stephen Woodbridge
> <woodbri at SWOODBRIDGE.COM> on Sun, 24 Apr 2005 23:23:26 -0400.
>>Hi all,
>>I'm looking at the SWIGMapScript doc and have run into a few problems.
>>$mapObj->setExtent($minx, $miny, $maxx, $maxy);
>>and throws an error:
>>Can't locate auto/mapscript/mapObj/setExtent.al in @INC (@INC contains:
>>/etc/perl /usr/local/lib/perl/5.8.4 /usr/local/share/perl/5.8.4
>>/usr/lib/perl5 /usr/share/perl5 /usr/lib/perl/5.8 /usr/share/perl/5.8
>>/usr/local/lib/site_perl /usr/local/lib/perl/5.8.0
>>/usr/local/share/perl/5.8.0 .) at index.cgi line 255
>>Also looking at the document it looks like there is an
>>$layerObj->setExtent(...) which doesn't seem to be correct.
>>The classObj doc says it "Provides access to all class parameters
>>(color, symbol, label, & etc...)." but there is no doc to indicate there
>>is a symbol property, nor is there any of doc/properties for color,
>>overlaycolor, size, overlaysize. I think these were moved to styleObjs
>>so it might be appropriate to comment on that.
> Steve,
> What version are you using?
> I just double checked and there is most certainly a 'setExtent' for the
> mapObj in the mapscript.pm.
> You are correct on the classObj not. It is an old note that needs to be
> deleted. Sorry for the confusion.
> Lowell
