WFS Client Problems
Tyler Mitchell
tylermitchell at SHAW.CA
Fri Apr 29 00:24:16 EDT 2005
Hi Jeffrey,
The bad news is that it isn't really a WFS server! Unless I'm seriously
missing something - this server is lying saying that it is WFS (repeatedly
used in the capabilities document). Looking its capabilities document:
http://webservices.ionicsoft.com/unData/wfs/UN?request=capabilities
doesn't show any sign of really being a WFS, but only a WMS (although the
acronym is used there a lot).
If you know the people that put this together (anyone on this list!?), direct
them our way so we can help fix them up. Can you show us how you got it to
return GML properly, other than for a feature query?
The good news is, it is a WMS and works. Here is the layer definition that
should work for you.
LAYER
NAME country
TYPE RASTER
STATUS DEFAULT
CONNECTIONTYPE WMS
CONNECTION "http://webservices.ionicsoft.com/unData/wfs/UN?"
METADATA
"wms_server_version" "1.0.0"
"wms_name" "COUNTRY"
"wms_format" "PNG"
END
PROJECTION
"init=epsg:4326"
END
END
You won't be able to style the layers or change colours, but they've done a
good job making things look alright.
Let me know if you need more help. Please cc: me directly to get my
attention.
Tyler
On April 28, 2005 02:57 pm, Jeffrey Johnson wrote:
> Hello list,
> I am having trouble getting mapserver to properly retrieve and display
> data via wfs, and wanted to see if anyone can help. Mapserver is
> compiled with wfs and wms client support and the wms client works
> fine.
> Ok, here is the layer definition in my map file.
> LAYER
> NAME countries
> TYPE POLYGON
> STATUS ON
> CONNECTIONTYPE WFS
> CONNECTION
> "http://webservices.ionicsoft.com/unData/wfs/UN?" METADATA
> "wfs_service" "WFS"
> "wfs_typename" "wfs:COUNTRY"
> "wfs_version" "1.0.0"
> END
> PROJECTION
> "init=epsg:4326"
> END
> CLASS
> TEMPLATE "dummy.html"
> OUTLINECOLOR 0 0 0
> END
> END
> Note: dummy.html doesn't actually exist, but I dont think it has to???
> There are no errors returned with this layer is activated, but the
> output in the IMAGEPATH dir looks like this, and nothing is drawn.
> <?xml version='1.0' encoding='utf-8' ?> <ogcwfs:FeatureCollection
> xsi:schemaLocation="http://www.ionicsoft.com/wfs
> http://webservices.ionicsoft.com/unData/wfs/UN?REQUEST=DescribeAllFeatureTy
>pe&SERVICE=WFS http://www.opengis.net/wfs
> http://webservices.ionicsoft.com/unData/wfs/UN/REQUEST/get/DATA/LPR/wfs/bas
>ic.xsd" xmlns:gml="http://www.opengis.net/gml"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:xlink="http://www.w3.org/1999/xlink"
> xmlns:ogcwfs="http://www.opengis.net/wfs">
> <gml:boundedBy> <gml:null>inapplicable</gml:null>
> </gml:boundedBy>
> </ogcwfs:FeatureCollection>
> I assume that this means Mapserver made a request to the wfs server,
> but no results were returned. First of all, how do I find out the
> exact URL request made to the WFS server? I suppose that I may be able
> to debug it this way. I can construct a url myself and the server
> returns GML correctly.
> Thanks in advance,
> Jeff
