Error making mapscript tcl
Phil Dillon-Thiselton
dibblethewrecker at JIWE.ORG
Tue Aug 2 11:03:19 EDT 2005
> -----Original Message-----
> From: Nikos [mailto:nicolas at MAICH.GR]
> Sent: 02 August 2005 13:43
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] Error making mapscript tcl
> Philip Dillon-Thiselton wrote:
> > OK - I hurdled that little problem - mapserver-workbench then wanted
> > mkWidgets, i fixed that ok but now...
> How didi you fix the previous problem Philip?
I switched to tcl 8.3.5 as you suggested to build against and it worked fine
> > [mapserver-workbench] : msedit.tcl
> > Error in startup script: can't find package msTclObjs
> > while executing
> > "package require msTclObjs"
> > (file "/usr/bin/msedit.tcl" line 23)
> > I can't even find msTclObjs mentioned on teh net except for on the
> > mapserver related sites - what is it?
> msTclObjs is a package included with msworkbench. It is an object
> wrapperthat uses the obstcl package.
> You msworkbench distro should have it, as well as someother packages in
> it..
So it should be in
http://download.sourceforge.net/msworkbench/msworkbench-0.3.tar.gz
> I've fiddled with the msTclObjs package to use Itcl, which is more
> maintained than the obstcl package..
> Let me know if you want a copy..
If you can help implement it - I am putting this all together for Live GIS
distribution :)
> regards,
> nikos
> > Phil
