Error making mapscript tcl
Phil Dillon-Thiselton
dibblethewrecker at JIWE.ORG
Wed Aug 3 06:33:58 EDT 2005
> -----Original Message-----
> From: Phil Dillon-Thiselton [mailto:dibblethewrecker at JIWE.ORG]
> Sent: 02 August 2005 16:03
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] Error making mapscript tcl
> > From: Nikos [mailto:nicolas at MAICH.GR]
> > Sent: 02 August 2005 13:43
> > Philip Dillon-Thiselton wrote:
> > > OK - I hurdled that little problem - mapserver-workbench then wanted
> > > mkWidgets, i fixed that ok but now...
> > How didi you fix the previous problem Philip?
> I switched to tcl 8.3.5 as you suggested to build against and it worked
> fine
> > > [mapserver-workbench] : msedit.tcl
> > > Error in startup script: can't find package msTclObjs
> > > while executing
> > > "package require msTclObjs"
> > > (file "/usr/bin/msedit.tcl" line 23)
> > > I can't even find msTclObjs mentioned on teh net except for on the
> > > mapserver related sites - what is it?
> > msTclObjs is a package included with msworkbench. It is an object
> > wrapperthat uses the obstcl package.
> > You msworkbench distro should have it, as well as someother packages in
> > it..
> So it should be in
> http://download.sourceforge.net/msworkbench/msworkbench-0.3.tar.gz
All sorted - I found the 3 directories for the included tools in the src dir
- I have NO idea how I missed them before - I scoured that dir looking the
files - even ran find! So, all good here - thanks for the help
> > I've fiddled with the msTclObjs package to use Itcl, which is more
> > maintained than the obstcl package..
> > Let me know if you want a copy..
> If you can help implement it - I am putting this all together for Live GIS
> distribution :)
> > regards,
> > nikos
> > > Phil
