Mapserver Setup Problems, Any Suggestions?
blaise
bpicinbono at WORLDONLINE.FR
Tue Aug 9 14:17:14 EDT 2005
lundi 8 Août 2005 18:46, Trevor Penney :
> Hi All,
> I am having some problems with setting up mapserver, any suggestions would
> be greatly appreciated.
> Basically I want to install mapserver. I have root access and Fedora Core
> 2. However, I can't use gcc to compile the mapserver from source, and
> unfortunately FGS isn't an option because I can't run more than 1 http.d,
> due for server reasons. Any suggestions on a work around, such as an RPM or
> something?
> If you know of anyone else I could contact that would be great.
> Thanks for any input!
> Trevor Penney
Why can't you use the gcc compiler ?
Blaise
