Oracle DATA problem as WFS
Uli Rothstein (CCGIS)
uli.rothstein at CCGIS.DE
Wed Jan 12 02:49:17 EST 2005
we have a problem using MapServer as WFS. The WMS connection works fine we
get a map. The WFS on the same connection returns a nice capabilities doc
but DescribeFeature will not give us a list of features.
<?xml version='1.0' encoding="ISO-8859-1" ?>
<schema
targetNamespace="http://www.ttt.org/myns"
xmlns:myns="http://www.ttt.org/myns"
xmlns:ogc="http://www.opengis.net/ogc"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xmlns="http://www.w3.org/2001/XMLSchema"
xmlns:gml="http://www.opengis.net/gml"
elementFormDefault="qualified" version="0.1" >
<import namespace="http://www.opengis.net/gml"
schemaLocation="../gml/2.1.1/feature.xsd" />
<element name="ALK_WFS"
type="myns:ALK_WFS_Type"
substitutionGroup="gml:_Feature" />
<complexType name="ALK_WFS_Type">
<complexContent>
<extension base="gml:AbstractFeatureType">
<sequence>
<element ref="gml:polygonProperty" minOccurs="0" />
</sequence>
</extension>
</complexContent>
</complexType>
</schema>
This is our MAP file snippet:
LAYER
NAME "ALK_WFS"
STATUS ON
METADATA
"WFS_SRS" "epsg:31467"
"WFS_TITLE" "spatial"
"WFS_FEATURE_INFO_MIME_TYPE" "text/html"
"WFS_EXTENT" "3300000 5400000 3500000 5650000"
END
CONNECTIONTYPE oraclespatial
CONNECTION "*****"
DATA "GEO_COORD_ AS GEOM, GMNR AS ITEM_GEMARKUNG, FLNR AS ITEM_FLUR,
FSNR AS ITEM_FLSTCK, FUNR AS ITEM_NENNER, QUELLE AS QUELLE FROM
FLO.FLO_AL125_AGGREGA_VW USING SRID 82027"
TYPE POLYGON
DUMP TRUE
PROJECTION
"init=epsg:31467"
END
END
We tried several DATA strings, this is one of them:
DATA "GEO_COORD_ FROM (SELECT GMNR AS ITEM_GEMARKUNG, FLNR AS ITEM_FLUR,
FLO.FLO_AL125_AGGREGA_VW) USING SRID 82027"
To no avail. Any ideas?
Best regards,
Arnulf
