Oracle DATA problem as WFS
Fernando Simon
fsimon at UNIVALI.BR
Wed Jan 12 06:23:15 EST 2005
I believe that the problem is with Mapserver version, I don't know
if the 4.2 and older work, only 4.4 and newer.
If you are using the 4.4 version you need to define the "unique
column" in your data string. Like: DATA "GEOM FROM (SELECT GEO_COORD_
AS GEOM, GMNR AS ITEM_GEMARKUNG, FLNR AS ITEM_FLUR, FSNR AS
ITEM_FLSTCK, FUNR AS ITEM_NENNER, QUELLE AS QUELLE FROM
FLO.FLO_AL125_AGGREGA_VW) USING UNIQUE "<YOUR PKEY>" SRID 82027".
Where the "<YOUR PKEY>" is your a numeric column that store the
unique identifier for the rows in your table (usually the primary
key).
Thanks.
Fernando Simon
Mapserver and Oracle Spatial developer
G10 - Laboratorio de Computacao Aplicada - Brazil
http://g10.cttmar.univali.br - UNIVALI/CTTMAR
Citando "Uli Rothstein (CCGIS)" <uli.rothstein at CCGIS.DE>:
> Hi,
> we have a problem using MapServer as WFS. The WMS connection works
> fine we
> get a map. The WFS on the same connection returns a nice
> capabilities doc
> but DescribeFeature will not give us a list of features.
> <?xml version='1.0' encoding="ISO-8859-1" ?>
> <schema
> targetNamespace="http://www.ttt.org/myns"
> xmlns:myns="http://www.ttt.org/myns"
> xmlns:ogc="http://www.opengis.net/ogc"
> xmlns:xsd="http://www.w3.org/2001/XMLSchema"
> xmlns="http://www.w3.org/2001/XMLSchema"
> xmlns:gml="http://www.opengis.net/gml"
> elementFormDefault="qualified" version="0.1" >
> <import namespace="http://www.opengis.net/gml"
> schemaLocation="../gml/2.1.1/feature.xsd" />
> <element name="ALK_WFS"
> type="myns:ALK_WFS_Type"
> substitutionGroup="gml:_Feature" />
> <complexType name="ALK_WFS_Type">
> <complexContent>
> <extension base="gml:AbstractFeatureType">
> <sequence>
> <element ref="gml:polygonProperty" minOccurs="0" />
> </sequence>
> </extension>
> </complexContent>
> </complexType>
> </schema>
> This is our MAP file snippet:
> LAYER
> NAME "ALK_WFS"
> STATUS ON
> METADATA
> "WFS_SRS" "epsg:31467"
> "WFS_TITLE" "spatial"
> "WFS_FEATURE_INFO_MIME_TYPE" "text/html"
> "WFS_EXTENT" "3300000 5400000 3500000 5650000"
> END
> CONNECTIONTYPE oraclespatial
> CONNECTION "*****"
> DATA "GEO_COORD_ AS GEOM, GMNR AS ITEM_GEMARKUNG, FLNR AS
> ITEM_FLUR,
> FSNR AS ITEM_FLSTCK, FUNR AS ITEM_NENNER, QUELLE AS QUELLE FROM
> FLO.FLO_AL125_AGGREGA_VW USING SRID 82027"
> TYPE POLYGON
> DUMP TRUE
> PROJECTION
> "init=epsg:31467"
> END
> END
> We tried several DATA strings, this is one of them:
> DATA "GEO_COORD_ FROM (SELECT GMNR AS ITEM_GEMARKUNG, FLNR AS
> ITEM_FLUR,
> FLO.FLO_AL125_AGGREGA_VW) USING SRID 82027"
> To no avail. Any ideas?
> Best regards,
> Arnulf
Univali - Webmail - http://webmail.univali.br
