Need Help Displaying Info from DBFs
Michael Elepano
michael at LIVEPROCESS.COM
Fri Jan 14 13:08:46 EST 2005
Hey:
I've been using MapServer for about a month now and have gotten
relatively far with it. But now I've hit a brick wall.
The problem I'm having is showing info from DBFs on my map of the US.
I've got two DBFs (one with all the US counties and one with data-- say
occurences of avalanches-- for each of those county). I'm trying to
color code each county according to occurences of avalanches.
Each DBF has a column called FIPS. The avalanche DBF has a column
called COUNT that is the basis for my colors. I can use EXPRESSION to
single out any column in my county DBF, but I can't seem to reach my
avalanche DBF.
I'm assuming I'll need to do a JOIN. My attempt follows below. Any
advice would be appreciated.
Michael
## my attempt at an avalanche layer
LAYER
NAME "layerAvalanche"
TYPE POLYGON
STATUS ON
DATA "counties.dbf"
PROJECTION
"proj=latlong"
"ellps=GRS80"
"datum=NAD83"
END
CLASS
NAME "classGreen"
OUTLINECOLOR 255 0 255
COLOR 0 255 0
EXPRESSION ([COUNT] > 5)
END
JOIN
NAME "joinAvalanche"
TABLE "C:\my\path\to\avalanches.dbf"
FROM "FIPS"
TO "FIPS"
END
END
