mapserver4.6.0 config failure
Jim Ballantine
j.ballantine at GMAIL.COM
Wed Jul 6 12:50:53 EDT 2005
It's pointing to where it is installed.
On 7/6/05, Frank Warmerdam <fwarmerdam at gmail.com> wrote:
> On 7/6/05, Jim Ballantine <j.ballantine at gmail.com> wrote:
> > Hi,
> > I'm trying to build MapServer-4.6.0 on a sun solaris8 box, and the
> > configure is failing with:
> > MapServer Version from map.h: '4.6.0'
> > configure: checking where FreeType 2.x is installed...
> > using libfreetype from -L/usr/local/add-on/freetype/lib -lfreetype
> > configure: checking where Zlib is installed...
> > using libz from -L/usr/local/add-on/zlib/lib -lz
> > configure: checking where PNG is installed...
> > using libpng from -L/usr/local/add-on/libpng/lib -lpng
> > configure: checking whether we should include JPEG support...
> > using libjpeg from system -L/usr/local/add-on/jpeg/lib -ljpeg
> > configure: checking where libXpm is installed...
> > using libXpm from -L/usr/local/add-on/xpm/lib -lXpm -lX11
> > configure: checking where libiconv is installed...
> > checking for iconv_open in -lc... yes
> > checking for libiconv_open in -liconv... no
> > using libiconv from -L -lc
> > libiconv found. Enabling internationalization (-DUSE_ICONV)
> > configure: checking for GD 2.0.16 or higher...
> > DEBUG: GD_DIR 1 is set to /usr/local/add-on/gd-2.0.33
> > DEBUG: GD_DIR 2 is set to /usr/local/add-on/gd-2.0.33
> > DEBUG: GD_LIBDIR is set to /usr/local/add-on/gd-2.0.33/lib :
> > gdFontCacheSetup is
> > checking for gdFontCacheSetup in -lgd... no
> > configure: checking whether GD needs libiconv...
> > configure: error: Could not find gd.h or libgd.a/libgd.so in
> > /usr/local/add-on/gd-2.0.33. Make sure GD 2.0.16 or higher is
> > compiled before calling configure. You may also get this error if you
> > didn't specify the appropriate location for one of GD's dependencies
> > (freetype, libpng, libjpeg or libiconv).
> > I added the DEBUG echo's to see what what going on.
> > When I check /usr/local/add-on/gd-2.0.33/include/gd.h, I get:
> > and when I look at libgd.a, nm
> > /usr/local/add-on/gd-2.0.33/lib/libgd.a | grep gdFontCacheSetup, I
> > get:
> > [70] | 2872| 132|FUNC |GLOB |0 |2 |gdFontCacheSetup
> > /usr/local/add-on/freetype points to /usr/local/add-on/freetype-2.1.3
> > Anyone have any ideas on what I'm missing????
> Jim,
> Are you pointing configure at the directory where you built GD or
> where it was installed? Often the ability to point to build directories
> for packages is very fragile, and it is easier to install it in a custom
> location and then point at that install tree.
> Of course, I could easily be barking up the wrong tree. Just one
> wild speculation.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
