mapserver4.6.0 config failure
Frank Warmerdam
fwarmerdam at GMAIL.COM
Wed Jul 6 12:03:17 EDT 2005
On 7/6/05, Jim Ballantine <j.ballantine at gmail.com> wrote:
> Hi,
> I'm trying to build MapServer-4.6.0 on a sun solaris8 box, and the
> configure is failing with:
> MapServer Version from map.h: '4.6.0'
> configure: checking where FreeType 2.x is installed...
> using libfreetype from -L/usr/local/add-on/freetype/lib -lfreetype
> configure: checking where Zlib is installed...
> using libz from -L/usr/local/add-on/zlib/lib -lz
> configure: checking where PNG is installed...
> using libpng from -L/usr/local/add-on/libpng/lib -lpng
> configure: checking whether we should include JPEG support...
> using libjpeg from system -L/usr/local/add-on/jpeg/lib -ljpeg
> configure: checking where libXpm is installed...
> using libXpm from -L/usr/local/add-on/xpm/lib -lXpm -lX11
> configure: checking where libiconv is installed...
> checking for iconv_open in -lc... yes
> checking for libiconv_open in -liconv... no
> using libiconv from -L -lc
> libiconv found. Enabling internationalization (-DUSE_ICONV)
> configure: checking for GD 2.0.16 or higher...
> DEBUG: GD_DIR 1 is set to /usr/local/add-on/gd-2.0.33
> DEBUG: GD_DIR 2 is set to /usr/local/add-on/gd-2.0.33
> DEBUG: GD_LIBDIR is set to /usr/local/add-on/gd-2.0.33/lib :
> gdFontCacheSetup is
> checking for gdFontCacheSetup in -lgd... no
> configure: checking whether GD needs libiconv...
> configure: error: Could not find gd.h or libgd.a/libgd.so in
> /usr/local/add-on/gd-2.0.33. Make sure GD 2.0.16 or higher is
> compiled before calling configure. You may also get this error if you
> didn't specify the appropriate location for one of GD's dependencies
> (freetype, libpng, libjpeg or libiconv).
> I added the DEBUG echo's to see what what going on.
> When I check /usr/local/add-on/gd-2.0.33/include/gd.h, I get:
> and when I look at libgd.a, nm
> /usr/local/add-on/gd-2.0.33/lib/libgd.a | grep gdFontCacheSetup, I
> get:
> [70] | 2872| 132|FUNC |GLOB |0 |2 |gdFontCacheSetup
> /usr/local/add-on/freetype points to /usr/local/add-on/freetype-2.1.3
> Anyone have any ideas on what I'm missing????
Jim,
Are you pointing configure at the directory where you built GD or
where it was installed? Often the ability to point to build directories
for packages is very fragile, and it is easier to install it in a custom
location and then point at that install tree.
Of course, I could easily be barking up the wrong tree. Just one
wild speculation.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
