mapserver4.6.0 config failure
Jim Ballantine
j.ballantine at GMAIL.COM
Wed Jul 6 10:56:12 EDT 2005
I'm trying to build MapServer-4.6.0 on a sun solaris8 box, and the
configure is failing with:
MapServer Version from map.h: '4.6.0'
configure: checking where FreeType 2.x is installed...
using libfreetype from -L/usr/local/add-on/freetype/lib -lfreetype
configure: checking where Zlib is installed...
using libz from -L/usr/local/add-on/zlib/lib -lz
configure: checking where PNG is installed...
using libpng from -L/usr/local/add-on/libpng/lib -lpng
configure: checking whether we should include JPEG support...
using libjpeg from system -L/usr/local/add-on/jpeg/lib -ljpeg
configure: checking where libXpm is installed...
using libXpm from -L/usr/local/add-on/xpm/lib -lXpm -lX11
configure: checking where libiconv is installed...
checking for iconv_open in -lc... yes
checking for libiconv_open in -liconv... no
using libiconv from -L -lc
libiconv found. Enabling internationalization (-DUSE_ICONV)
configure: checking for GD 2.0.16 or higher...
DEBUG: GD_DIR 1 is set to /usr/local/add-on/gd-2.0.33
DEBUG: GD_DIR 2 is set to /usr/local/add-on/gd-2.0.33
DEBUG: GD_LIBDIR is set to /usr/local/add-on/gd-2.0.33/lib :
gdFontCacheSetup is
checking for gdFontCacheSetup in -lgd... no
configure: checking whether GD needs libiconv...
configure: error: Could not find gd.h or libgd.a/libgd.so in
/usr/local/add-on/gd-2.0.33. Make sure GD 2.0.16 or higher is
compiled before calling configure. You may also get this error if you
didn't specify the appropriate location for one of GD's dependencies
(freetype, libpng, libjpeg or libiconv).
I added the DEBUG echo's to see what what going on.
When I check /usr/local/add-on/gd-2.0.33/include/gd.h, I get:
and when I look at libgd.a, nm
/usr/local/add-on/gd-2.0.33/lib/libgd.a | grep gdFontCacheSetup, I
get:
[70] | 2872| 132|FUNC |GLOB |0 |2 |gdFontCacheSetup
/usr/local/add-on/freetype points to /usr/local/add-on/freetype-2.1.3
Anyone have any ideas on what I'm missing????
Thanks
Jim
