Connect to ESRI Personal Geodatabase
Flavio Hendry
flavio at TYDAC.CH
Fri Jul 8 01:46:40 EDT 2005
hi ken
seems to be a strategy to introduce as many formats as possible. if I
look at the FME list there are already 11 ESRI formats there. this is
nr. 12 ... from what I read, personal geodatabase will be history (one
more dead body) and the new "file based database" (!?) will be
the "standard". reading the text, the reason behind it might be that
personal geodatabase has bad performance.
good news are however: "Like it did with shapefiles, ESRI is providing
an open API that will allow anyone to create and use file-based
geodatabases."
I suppose it is not worth to invest to support a dead body ... ???
Mit freundlichem Gruss / Best Regards
Flavio Hendry
TYDAC NEWS http://www.tydac.ch/german/index.php?menu=News_actual
############ Mit freundlichen Gruessen / Kind Regards
############ mailto:flavio at tydac.ch
############ TYDAC AG - http://www.tydac.ch
#### #### Geographic Information Solutions
#### #### Luternauweg 12 -- CH-3006 Bern
############ Tel +41 (0)31 368 0180 - Fax +41 (0)31 368 1860
