Other spatial database development (PostGIS)
Paul Ramsey
pramsey at REFRACTIONS.NET
Fri Jul 8 08:00:25 PDT 2005
Read-only OleDB would probably work fine. It would still be some
effort to implement. Most people really consider read/write the gold
standard they need for ArcMap, which is why I was focussing on it.
Paul
On 8-Jul-05, at 6:18 AM, uli mueller wrote:
> Paul, why exactly are the signs not promising? Is
> it "only" because OLEDB provides read-only access for ArcGIS? I did
> not
> really delve into the article you cited, but what I read sounded like
> you can use PostGIS WKBs 1:1 with OLEDB for ArcGIS?? Has anybody
> successfully implemented read-access from ArcGIS 9 to PG? Would
> this be only an ugly or also a never-ending hack?
> Background: We also have a project where we are constrained to use
> a personal geodatabase and would be happy to switch to PostGIS.
> Read-only would be sufficient in this case.
> Uli
> geOps GeoInformatics
> D-79100 Freiburg
> Alex Smith wrote:
>> I'd like to preface this by acknowledging that my technical
>> ineptitude may have been the cause of my unsuccessful attempts to
>> write tabular data to external OLEDB databases from ArcGIS. And
>> I'd also like to point out that it's been a while since I tried
>> doing so - things may have changed. But my experiences have lead
>> me to believe that ESRI has (or had) carefully implemented ArcGIS
>> in a manner that prevents users from writing to external DBMS
>> without using ArcSDE. We do alot of spatial processing that
>> output and affects a considerable amount of tabular data that many
>> other rely on and edit where necessary. Because we're already
>> pushing the limits of Access, I looked into other options when we
>> started some new projects....and an affordable option, such as
>> Postgres or MySQL. Here's what I found
>> In the original "Exploring ArcObjects" book, published near the
>> release of ArcGIS 8.0, states that OLEDB connections to ArcGIS are
>> read only. Hence, we couldn't directly output data to an external
>> table joined to a Access based featureclass. Sure, we can later
>> use ADO to update the 'enterprise' database from the Access
>> geodatabase, but that starts to get messy or becomes, to use
>> Paul's words, a "moderately ugly hack" (why have the middle-man
>> Geodatabase tables - like pgArc had the middle-man shapefiles).
>> So I tried linking in a MySQL table to via ODBC in a
>> geodatabase .mdb file and attempted to edit that table (no spatial
>> data) from ArcGIS - I got a message stating that linked tables
>> cannot be written to. DAO tables (and I'm fairly certain that
>> ArcGIS interacts with Access databases using DAO), have a property
>> that returns true if they are linked tables. So it seems that
>> the ArcGIS has code that tests this property and does not allow
>> users to edit these tables. I fi
> nd it very
>> hard to believe that this was accidental. And I later felt naive
>> for thinking I could somehow 'outsmart' them - ESRI's software
>> engineers are not dumb. Expect some resistance in attempting to
>> circumnavigate their systems. I understand their need to protect
>> their investment - the ArcGIS spatial editting tools (including
>> topology and networks) and ArcSDE must have cost a lot of money to
>> develop. And it's good software - ESRI has earned a lot of its
>> success. It just sucks for those of us on a limited budget - SDE
>> licenses on top of commercial RDBMS fees is simply unaffordable in
>> our case. On the other hand, ESRI seems to be opening up. But
>> they must continue to recover their development costs somehow.
>> And I'd be surprised if they'd make it easy for other develop
>> tools to compete with their systems. Yes, being able to directly
>> edit PostGIS data using ArcGIS-like editing tools would be
>> huge....but I don't think that it would be easy and would probably
>> be cost-prohibitive. As Paul mentioned, if these things were
>> easily and cost-effectively attainable, then it probably would
>> have been done by now. But then again....look how successful
>> mapserver has become. Just my thoughts......
>> Alex
>> Paul Ramsey <pramsey at REFRACTIONS.NET> wrote:
>> Guys, I am happy to spec this out again, but frankly I fear that
>> most solutions will remain in the "moderately ugly hack" domain,
>> ala PgArc. I have investigated more elegant things (oledb) but the
>> signs are not promising (http://arcgisdeveloperonline.esri.com/
>> ArcGISDeveloper/ExtendingArcObjects/Ch07/AboutOLEDBProviders.htm).
>> Principally, the continuing lack of an Oracle Spatial third party
>> read/write extension on the market says to me that such a thing is
>> just technically not possible to do attractively. If it were,
>> someone would have written it by now and be making money on it. If
>> anyone knows of such a thing, please do tell, it would be a good
>> positive sign of possible success.
>> Paul
>> On 7-Jul-05, at 10:22 AM, Ken Lord wrote:
>>> Hi Mike,
>>> This is a major interest to us, we would like to see a push for
>>> this as well, in fact I was just asked to contact Tyler Mitchell
>>> about pgArc when I return from my holidays. Tyler! are your ears
>>> burning? hehe
>>> pgArc can be found at SourceForge if you want to check it out. It
>>> has some functionality with ArcGIS 8, but I haven't had it work
>>> with ArcGIS 9.
>>> We are locked into personal geodatabases for some of our clients,
>>> development of a fully functional ArcGIS / PostGIS connection
>>> would give us a lot more flexibility too.
>>> Cheers,
>>> Ken Lord
>>> Vancouver BC
>>> On 7/7/05, Mike Davis wrote: Since we seem to be building some
>>> momentum on the ESRI personal
>>> geodatabase thing, it seems like a good time to bring up the other
>>> database related item on our wishlist.
>>> What would be required to allow read/write to a PostGIS database
>>> from
>>> ArcGIS? I would love the ability to maintain our spatial data in
>>> multiple datbase formats (must me my irrational fear of vendor
>>> lock-in), but unless we can manage the data from within ArcGIS it
>>> isn't really a practical option for us.
>>> -Mike
>> __________________________________________________
>> Do You Yahoo!?
>> Tired of spam? Yahoo! Mail has the best spam protection around
>> http://mail.yahoo.com
> D-79100 Freiburg
More information about the MapServer-users
