Other spatial database development (PostGIS)
Paul Ramsey
pramsey at REFRACTIONS.NET
Fri Jul 8 15:45:24 EDT 2005
The plot thickens:
http://support.esri.com/
index.cfm?fa=knowledgebase.techarticles.articleShow&d=16643
P
On Friday, July 8, 2005, at 08:00 AM, Paul Ramsey wrote:
> Read-only OleDB would probably work fine. It would still be some
> effort to implement. Most people really consider read/write the gold
> standard they need for ArcMap, which is why I was focussing on it.
> Paul
> On 8-Jul-05, at 6:18 AM, uli mueller wrote:
>> Paul, why exactly are the signs not promising? Is
>> it "only" because OLEDB provides read-only access for ArcGIS? I did
>> not
>> really delve into the article you cited, but what I read sounded like
>> you can use PostGIS WKBs 1:1 with OLEDB for ArcGIS?? Has anybody
>> successfully implemented read-access from ArcGIS 9 to PG? Would this
>> be only an ugly or also a never-ending hack?
>> Background: We also have a project where we are constrained to use a
>> personal geodatabase and would be happy to switch to PostGIS.
>> Read-only would be sufficient in this case.
>> Uli
>> geOps GeoInformatics
>> D-79100 Freiburg
>> Alex Smith wrote:
>>> I'd like to preface this by acknowledging that my technical
>>> ineptitude may have been the cause of my unsuccessful attempts to
>>> write tabular data to external OLEDB databases from ArcGIS. And I'd
>>> also like to point out that it's been a while since I tried doing so
>>> - things may have changed. But my experiences have lead me to
>>> believe that ESRI has (or had) carefully implemented ArcGIS in a
>>> manner that prevents users from writing to external DBMS without
>>> using ArcSDE. We do alot of spatial processing that output and
>>> affects a considerable amount of tabular data that many other rely
>>> on and edit where necessary. Because we're already pushing the
>>> limits of Access, I looked into other options when we started some
>>> new projects....and an affordable option, such as Postgres or MySQL.
>>> Here's what I found
>>> In the original "Exploring ArcObjects" book, published near the
>>> release of ArcGIS 8.0, states that OLEDB connections to ArcGIS are
>>> read only. Hence, we couldn't directly output data to an external
>>> table joined to a Access based featureclass. Sure, we can later use
>>> ADO to update the 'enterprise' database from the Access geodatabase,
>>> but that starts to get messy or becomes, to use Paul's words, a
>>> "moderately ugly hack" (why have the middle-man Geodatabase tables -
>>> like pgArc had the middle-man shapefiles). So I tried linking in a
>>> MySQL table to via ODBC in a geodatabase .mdb file and attempted to
>>> edit that table (no spatial data) from ArcGIS - I got a message
>>> stating that linked tables cannot be written to. DAO tables (and
>>> I'm fairly certain that ArcGIS interacts with Access databases using
>>> DAO), have a property that returns true if they are linked tables.
>>> So it seems that the ArcGIS has code that tests this property and
>>> does not allow users to edit these tables. I fi
>> nd it very
>>> hard to believe that this was accidental. And I later felt naive
>>> for thinking I could somehow 'outsmart' them - ESRI's software
>>> engineers are not dumb. Expect some resistance in attempting to
>>> circumnavigate their systems. I understand their need to protect
>>> their investment - the ArcGIS spatial editting tools (including
>>> topology and networks) and ArcSDE must have cost a lot of money to
>>> develop. And it's good software - ESRI has earned a lot of its
>>> success. It just sucks for those of us on a limited budget - SDE
>>> licenses on top of commercial RDBMS fees is simply unaffordable in
>>> our case. On the other hand, ESRI seems to be opening up. But
>>> they must continue to recover their development costs somehow. And
>>> I'd be surprised if they'd make it easy for other develop tools to
>>> compete with their systems. Yes, being able to directly edit
>>> PostGIS data using ArcGIS-like editing tools would be huge....but I
>>> don't think that it would be easy and would probably be
>>> cost-prohibitive. As Paul mentioned, if these things were easily
>>> and cost-effectively attainable, then it probably would have been
>>> done by now. But then again....look how successful mapserver has
>>> become. Just my thoughts......
>>> Alex
>>> Paul Ramsey <pramsey at REFRACTIONS.NET> wrote:
>>> Guys, I am happy to spec this out again, but frankly I fear that
>>> most solutions will remain in the "moderately ugly hack" domain, ala
>>> PgArc. I have investigated more elegant things (oledb) but the signs
>>> are not promising (http://arcgisdeveloperonline.esri.com/
>>> ArcGISDeveloper/ExtendingArcObjects/Ch07/AboutOLEDBProviders.htm).
>>> Principally, the continuing lack of an Oracle Spatial third party
>>> read/write extension on the market says to me that such a thing is
>>> just technically not possible to do attractively. If it were,
>>> someone would have written it by now and be making money on it. If
>>> anyone knows of such a thing, please do tell, it would be a good
>>> positive sign of possible success.
>>> Paul
>>> On 7-Jul-05, at 10:22 AM, Ken Lord wrote:
>>>> Hi Mike,
>>>> This is a major interest to us, we would like to see a push for
>>>> this as well, in fact I was just asked to contact Tyler Mitchell
>>>> about pgArc when I return from my holidays. Tyler! are your ears
>>>> burning? hehe
>>>> pgArc can be found at SourceForge if you want to check it out. It
>>>> has some functionality with ArcGIS 8, but I haven't had it work
>>>> with ArcGIS 9.
>>>> We are locked into personal geodatabases for some of our clients,
>>>> development of a fully functional ArcGIS / PostGIS connection would
>>>> give us a lot more flexibility too.
>>>> Cheers,
>>>> Ken Lord
>>>> Vancouver BC
>>>> On 7/7/05, Mike Davis wrote: Since we seem to be building some
>>>> momentum on the ESRI personal
>>>> geodatabase thing, it seems like a good time to bring up the other
>>>> database related item on our wishlist.
>>>> What would be required to allow read/write to a PostGIS database
>>>> from
>>>> ArcGIS? I would love the ability to maintain our spatial data in
>>>> multiple datbase formats (must me my irrational fear of vendor
>>>> lock-in), but unless we can manage the data from within ArcGIS it
>>>> isn't really a practical option for us.
>>>> -Mike
>>> __________________________________________________
>>> Do You Yahoo!?
>>> Tired of spam? Yahoo! Mail has the best spam protection around
>>> http://mail.yahoo.com
>> D-79100 Freiburg
Paul Ramsey
Refractions Research
Email: pramsey at refractions.net
Phone: (250) 885-0632
