Serving A Large Archive an openpap-client/wms-server
Norman Vine
nhv at CAPE.COM
Sun Jul 10 03:18:44 PDT 2005
John Bonk writes:
> We have a lot of data on an opendap server. We had plans for a
> MapServer opendap-client/wms-server--in other words we wanted to build
> a MapServer that will serve raster data from our opendap server.
> We were working on a prototype that will serve one of our products.
> The product consists of monthly files, each file contains 2 parameters
> per file. At present there are over 80 months (files) of data.
> I still consider myself a novice and may have some misconceptions
> about MapServer, but my understanding is that to offer this data I will
> need a mapfile with over 160 layers--one for each file times 2 for the
> 2 parameters.
> I read in one of the documents
> (http://mapserver.gis.umn.edu/doc44/mapfile-reference.html) that there
> is a 50 layer limit for a mapfile. The document said that this limit
> could be raised by making a change to map.h. However, some of our
> products have files containing over a hundred parameters. I estimate
> that if we wanted to offer each of the parameters in each file for
> several of our products, we would need a mapfile with hundreds of
> thousands layers. Are we expecting too much from mapserver?
> Is there any way around this problem?
> Does anyone have any suggestions for serving data that is scattered
> through thousands of files?
Hi John,
I haven't used it but Mapserver has some support for temporal REQUESTS
This might mean you only need to have 2 layers
http://mapserver.gis.umn.edu/doc44/wms-time-support-howto.html
Although primarily a 1.3 WMS there is some discussion about 1.1 WMS
time support in the docs for this server
http://aes.gsfc.nasa.gov/documents/overview.html
Not exactly sure how this would be set up for UMN MapServer though
Hopefully someone more knowlegable will chime in on this
HTH
Norman
More information about the MapServer-users
