mapscript concurent access
Umberto Nicoletti
umberto.nicoletti at GMAIL.COM
Mon Jul 11 07:23:43 EDT 2005
On 7/11/05, Stéphane RIFF <stephane.riff at cerene.fr> wrote:
> Hello
> I have an application thet serve map over internet :
> mapserver 4.4.2, mapscript, postgis + rasters
> I think there is some problem occur when there are more than one user
> connected to the server.
> I can't see error in mapserthonver log nor in php log.
> Those errors occurs only when accessing postgis.
> All the application is write in mapscript without use mapserv.exe.
Which mapscript (Java, php, python)?
Did you compile it by yourself?
If yes what options did you supply to configure?
If not where did you get it form?
Regards,
umberto
> Does somebody know bugs about that ???
> Thanks
