mapscript concurent access
Stéphane RIFF
stephane.riff at CERENE.FR
Mon Jul 11 08:08:55 EDT 2005
I compile phpmapscript myself with those options :
./configure --with-proj=/usr/local/ --with-jpeg=/usr
--with-gd=/usr/local --with-freetype=/usr --with-png=/usr --with-ogr
--with-gdal=/usr/local/bin/gdal-config
--with-postgis=/usr/local/pgsql/bin/pg_config --with-php=../php-4.3.9/
Umberto Nicoletti wrote:
>On 7/11/05, Stéphane RIFF <stephane.riff at cerene.fr> wrote:
>>Hello
>>I have an application thet serve map over internet :
>> mapserver 4.4.2, mapscript, postgis + rasters
>>I think there is some problem occur when there are more than one user
>>connected to the server.
>>I can't see error in mapserthonver log nor in php log.
>>Those errors occurs only when accessing postgis.
>>All the application is write in mapscript without use mapserv.exe.
>Which mapscript (Java, php, python)?
>Did you compile it by yourself?
>If yes what options did you supply to configure?
>If not where did you get it form?
>Regards,
>umberto
>>Does somebody know bugs about that ???
>>Thanks
