mapscript concurent access
Umberto Nicoletti
umberto.nicoletti at GMAIL.COM
Mon Jul 11 09:55:06 EDT 2005
This has been discussed a week ago. Search the ML for this thread:
mapserver php and cgi/module and security issues
Regars,
Umberto
On 7/11/05, Stéphane RIFF <stephane.riff at cerene.fr> wrote:
> I compile phpmapscript myself with those options :
> ./configure --with-proj=/usr/local/ --with-jpeg=/usr
> --with-gd=/usr/local --with-freetype=/usr --with-png=/usr --with-ogr
> --with-gdal=/usr/local/bin/gdal-config
> --with-postgis=/usr/local/pgsql/bin/pg_config --with-php=../php-4.3.9/
> >>Hello
> >>I have an application thet serve map over internet :
> >> mapserver 4.4.2, mapscript, postgis + rasters
> >>I think there is some problem occur when there are more than one user
> >>connected to the server.
> >>I can't see error in mapserthonver log nor in php log.
> >>Those errors occurs only when accessing postgis.
> >>All the application is write in mapscript without use mapserv.exe.
> >Which mapscript (Java, php, python)?
> >Did you compile it by yourself?
> >If yes what options did you supply to configure?
> >If not where did you get it form?
> >Regards,
> >umberto
> >>Does somebody know bugs about that ???
> >>Thanks
