MAPSERVER-USERS Digest - 9 Jul 2005 to 10 Jul 2005 (#2005-197)
John Bonk
jpbonk at AOL.COM
Mon Jul 11 10:48:26 EDT 2005
>-John Bonk writes:
>> We have a lot of data on an opendap server. We had plans for a
>> MapServer opendap-client/wms-server--in other words we wanted to
build
>> a MapServer that will serve raster data from our opendap server.
>> We were working on a prototype that will serve one of our products.
>> The product consists of monthly files, each file contains 2
parameters
>> per file. At present there are over 80 months (files) of data.
>> I still consider myself a novice and may have some misconceptions
>> about MapServer, but my understanding is that to offer this data I
will
>> need a mapfile with over 160 layers--one for each file times 2 for
the
>> 2 parameters.
>> I read in one of the documents
>> (http://mapserver.gis.umn.edu/doc44/mapfile-reference.html) that
there
>> is a 50 layer limit for a mapfile. The document said that this
limit
>> could be raised by making a change to map.h. However, some of our
>> products have files containing over a hundred parameters. I
estimate
>> that if we wanted to offer each of the parameters in each file for
>> several of our products, we would need a mapfile with hundreds of
>> thousands layers. Are we expecting too much from mapserver?
>> Is there any way around this problem?
>> Does anyone have any suggestions for serving data that is scattered
>> through thousands of files?
>Hi John,
> I haven't used it but Mapserver has some support for temporal
REQUESTS
> This might mean you only need to have 2 layers
> http://mapserver.gis.umn.edu/doc44/wms-time-support-howto.html
> Although primarily a 1.3 WMS there is some discussion about 1.1 WMS
> time support in the docs for this server
> http://aes.gsfc.nasa.gov/documents/overview.html
> Not exactly sure how this would be set up for UMN MapServer though
> Hopefully someone more knowlegable will chime in on this
> HTH
> Norman
Norman,
Thanks for the suggestion. I read the doc on time support. I got the
impression that the document addresses the situation where all the time
periods are included in one file. Will someone please correct me if I
am wrong about this?
I'm toying with the idea of creating a GetCapabilities doc outside the
context the mapserver, with the two layers and a time time range as you
suggest above. A cgi script would create a map object using map script.
But my understanding of mapscript capabilities is, at this point,l very
weak so I don't know how feasible this is.
I may have to start with something considerably simpler and work my
way toward this.
Thanks for the link to aes. I think it may prove to be helpful.
John
