Mapfile TOLERANCE/ Mouse-click accuracy?
Nikos
nicolas at MAICH.GR
Tue Jul 12 05:31:01 EDT 2005
Hello,
I could use a bit of help here.
Using a simple shapefile of France, about 20 regions, under windows,
ms3.6 cgi, and standard html interface...
My problem is accuarcy when querying a polygon, e.g when I click on what
should be Corsica, I get the alps..
I've cranked up the TOLERANCE in my layer definition.. but all that does
is return more regions when "querying multiple" that does not really help..
No projection is set in mapfile
I've checked the shapefile with shpdump, and it reports the extents as
are in the mapfile
The shape file queries correctly in Arcview...
could use a bit of help here..
regards,
nicolas boretos
map
extent -5.18189952103 41.3328004925 9.5598004927 51.0886995016
imagecolor 255 255 255
name "france"
shapepath "data"
size 600 600
status on
symbolset "symbols/all.sym"
units KILOmeters
# 1 scalebar #none
scalebar
backgroundcolor 25 255 0
color 255 255 255
imagecolor 25 255 255
intervals 4
outlinecolor 0 0 0
size 200 7
status on
style 0
transparent TRUE
units meters
# 1 label #none
label
backgroundcolor 0 0 0
color 255 255 0
size tiny
end
end
# 2 layer regions
layer
classitem "COLZA_TN"
data "regions"
footer "regions_footer.html"
group "regions"
header "regions_header.html"
TOLERANCE 70
TRANSPARENCY 80
labelcache on
labelitem "COLZA_TN"
name "Regions"
postlabelcache true
status on
type polygon
# 1 class regions_1
class
backgroundcolor 128 128 128
color 85 34 221
name "regions_1_1"
NAME Regions
outlinecolor 0 0 0
template "regions_query.html"
end
#This is where the parametric query works..
end
# 3 web france.html
web
blah...
