Mapfile TOLERANCE/ Mouse-click accuracy?
Flavio Hendry
flavio at TYDAC.CH
Tue Jul 12 06:47:15 EDT 2005
salut
you should use any tolerance at all ...
Mit freundlichem Gruss / Best Regards
Flavio Hendry
TYDAC NEWS http://www.tydac.ch/german/index.php?menu=News_actual
############ Mit freundlichen Gruessen / Kind Regards
############ mailto:flavio at tydac.ch
############ TYDAC AG - http://www.tydac.ch
#### #### Geographic Information Solutions
#### #### Luternauweg 12 -- CH-3006 Bern
############ Tel +41 (0)31 368 0180 - Fax +41 (0)31 368 1860
-----Original Message-----
To: MAPSERVER-USERS at LISTS.UMN.EDU
Date: Tue, 12 Jul 2005 12:31:01 +0300
Subject: [UMN_MAPSERVER-USERS] Mapfile TOLERANCE/ Mouse-click accuracy?
> Hello,
> I could use a bit of help here.
> Using a simple shapefile of France, about 20 regions, under windows,
> ms3.6 cgi, and standard html interface...
> My problem is accuarcy when querying a polygon, e.g when I click on
> what
> should be Corsica, I get the alps..
> I've cranked up the TOLERANCE in my layer definition.. but all that
> does
> is return more regions when "querying multiple" that does not really
> help..
> No projection is set in mapfile
> I've checked the shapefile with shpdump, and it reports the extents
> as
> are in the mapfile
> The shape file queries correctly in Arcview...
> could use a bit of help here..
> regards,
> nicolas boretos
> map
> extent -5.18189952103 41.3328004925 9.5598004927 51.0886995016
> imagecolor 255 255 255
> name "france"
> shapepath "data"
> size 600 600
> status on
> symbolset "symbols/all.sym"
> units KILOmeters
> # 1 scalebar #none
> scalebar
> backgroundcolor 25 255 0
> color 255 255 255
> imagecolor 25 255 255
> intervals 4
> outlinecolor 0 0 0
> size 200 7
> status on
> style 0
> transparent TRUE
> units meters
> # 1 label #none
> label
> backgroundcolor 0 0 0
> color 255 255 0
> size tiny
> end
> end
> # 2 layer regions
> layer
> classitem "COLZA_TN"
> data "regions"
> footer "regions_footer.html"
> group "regions"
> header "regions_header.html"
> TOLERANCE 70
> TRANSPARENCY 80
> labelcache on
> labelitem "COLZA_TN"
> name "Regions"
> postlabelcache true
> status on
> type polygon
> # 1 class regions_1
> class
> backgroundcolor 128 128 128
> color 85 34 221
> name "regions_1_1"
> NAME Regions
> outlinecolor 0 0 0
> template "regions_query.html"
> end
> #This is where the parametric query works..
> end
> # 3 web france.html
> web
> blah...
