newbe- mapscript /pil
Richard Alexander
raxpl at ANGLESEY.GOV.UK
Wed Jul 13 05:26:56 PDT 2005
thanks Didrik,
yes it is a fault in the code - but not the one that causes the PIL
error...I copied out the code wrongly !
The PIL problem with the PNG seems very odd to me because the PNG image
produced does open in Gimp...and if I save it as tmp2.png from Gimp, it will
then open from PIL !
If I use file objects instead of images I get the same problem.
Does the code work for you at all with mapscript ?
RA
More information about the MapServer-users
