newbe- mapscript /pil
Didrik Pinte
dpinte at ITAE.BE
Wed Jul 13 08:56:09 EDT 2005
Le mercredi 13 juillet 2005 à 07:26 -0500, Richard Alexander a écrit :
> thanks Didrik,
> yes it is a fault in the code - but not the one that causes the PIL
> error...I copied out the code wrongly !
> The PIL problem with the PNG seems very odd to me because the PNG image
> produced does open in Gimp...and if I save it as tmp2.png from Gimp, it will
> then open from PIL !
> If I use file objects instead of images I get the same problem.
> Does the code work for you at all with mapscript ?
> RA
Got it --> PIL does not support PNG that are interlaced !
You need to change your outputformat to :
# PIL does not support interlaced images !!!
OUTPUTFORMAT
NAME png
DRIVER "GD/PNG"
MIMETYPE "image/png"
IMAGEMODE RGB
EXTENSION "png"
FORMATOPTION "INTERLACE=OFF"
END
Didrik
Name: not available
Desc: This is a digitally signed message part
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050713/9b790e4f/attachment.bin
