newbe- mapscript /pil
Richard Alexander
raxpl at ANGLESEY.GOV.UK
Wed Jul 13 09:24:42 EDT 2005
well done ! - now i'm back on track (using Tkinter to construct a
lightweight, desktop mapviewer)
have a very good day......no, have a very good week !
thanks
Richard
Got it --> PIL does not support PNG that are interlaced !
You need to change your outputformat to :
# PIL does not support interlaced images !!!
OUTPUTFORMAT
NAME png
DRIVER "GD/PNG"
MIMETYPE "image/png"
IMAGEMODE RGB
EXTENSION "png"
FORMATOPTION "INTERLACE=OFF"
END
Le mercredi 13 juillet 2005 a 07:26 -0500, Richard Alexander a Tcrit :
> thanks Didrik,
> yes it is a fault in the code - but not the one that causes the PIL
> error...I copied out the code wrongly !
> The PIL problem with the PNG seems very odd to me because the PNG image
> produced does open in Gimp...and if I save it as tmp2.png from Gimp, it will
> then open from PIL !
> If I use file objects instead of images I get the same problem.
> Does the code work for you at all with mapscript ?
> RA
