Raster zoom problem with ERDAS Imagine Files
Frank Warmerdam
fwarmerdam at GMAIL.COM
Wed Jul 13 09:47:38 EDT 2005
On 7/13/05, Paul Moen <pmoen at state.nd.us> wrote:
> Greetings,
> We seem to be having some problems with our color orthophotography. Our map service is using
> tiled county mosaics in an ERDAS Imagine (.img) (24 bit, RGB file) format. Errors will pop up in our
> 4.4 Mapserver instance when I try to zoom in past a scale of 1:9500 and color shifts occur after
> zooming past certain scales.
> The error is:
> PHP Warning: [MapServer Error]: IReadBlock failed at X offset 703, Y offset 675: GDALRasterIO()
> failed: drawGDAL() in drawmappm.php on line 105
> PHP Fatal error: Call to a member function on a non-object in drawmappm.php on line 228
Paul,
What platform are you working on? GDAL 1.2.5 is a bit old now. It
is possible an upgrade to GDAL 1.2.6 or GDAL CVS will help. There
have been a few fixes in the decompression code in GDAL's Imagine
reader in the last year or two.
Also, what platform are you on? I am wondering if "large file" support
might not have been enabled at build time. For instance, large files
were not supported on MacOS X with GDAL till quite recently (post 1.2.6).
This is clearly a GDAL problem, so you might just want to open a GDAL
bugzilla entry for the issue and we can pursue it from there.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
