Map size dependent label/feature size
David Bitner
osgis.lists at GMAIL.COM
Wed Jul 13 15:08:33 EDT 2005
Is there anyway that parameters for label and feature size in class
definitions can be made to be dependent on the size of the image?
When requesting a map at large width and heights in order to create
pdf printouts, the labels and line/point features get very tiny. In
this case, I would like them to be about the same when showing the map
at 300dpi as when showing them at 72dpi. This would also solve the
dilema when using Mapserver as a WMS using ArcMap as a WMS client by
allowing the printout to use the scaled text rather than everything
ending up miniscule.
Thanks
