Java Mapscript version 4.6
Ajay Ranipeta
sc0rp10nau at YAHOO.COM.AU
Thu Jul 14 02:19:14 EDT 2005
Hi list,
Anyone help me out here, I'm running windows, and I don't have a copy of
VC++, so I'm in a bind here. Has someone pre-compiled the new version of
java mapscript for mapserver 4.6. I would like to fix the problem specified
below, and i'm hoping the new version will fix it.
thx
Ajay
On Tue, 12 Jul 2005 09:57:04 -0500, Ajay Ranipeta <sc0rp10nau at YAHOO.COM.AU>
wrote:
>Hi list (and Sean Gillies),
>Got a (known) problem, and (desperately and urgently) need a fix (or even
>info). I'm using java mapscript on windows, and after zooming in a few
>times, i get the following error under the tomcat logs:
>java.lang.UnknownError: Failed to parse expression
> at edu.umn.gis.mapscript.mapscriptJNI.mapObj_draw(Native Method)
> at edu.umn.gis.mapscript.mapObj.draw(mapObj.java:397)
>Now I know there is a similar error with layers (bug 1266:
>http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1266), but i suspect it is
>the same problem.
>I'm using Java/Mapscript v.4.4 (from hobu's site). While the bug report says
>that it'll be fixed with version 4.6, I was just wondering if it is fixed
>with the new version? If so, does anyone have a copy of new version of java
>mapscript? If not, anyone kind enough to let me know how to compile one. I
>don't have a copy of Visual C++, (and hence a pre-compiled version would be
>much appritiated).
>Any help would be greatly appritiated.
>tia
>cheers,
>Ajay
