mapscript python build test error
Sean Gillies
sgillies at FRII.COM
Tue Jul 19 01:32:06 EDT 2005
On Jul 18, 2005, at 6:48 AM, Kralidis,Tom [Burlington] wrote:
> Hi,
> I am trying to build python mapscript from MapServer CVS and encounter
> errors when running the tests. I have not installed the package yet as
> root.
> An earlier message I sent on another mapscript topic suggested
> upgrading
> swig, but I have not done so yet (FYI I had to removed the -modern
> option from the swig command below); however I'm not sure if this is
> the
> cause of the test errors?
> Thanks alot
> ..Tom
Tom,
Usually, such OWSRequest errors are due to MapServer not configured
with WMS client/server support, but it seems that you are configuring
it properly. The final two test failures are due to bugs in the test
suite. I think you are probably good to go, it's unlikely that you will
be using the OWSRequest class.
What's your interest in the Python mapscript? You really ought to
upgrade to SWIG 1.3.21+ if you are going to try to use it with Python
versions 2.2 or higher. The -modern option results in a higher
performance module.
Sean
Sean Gillies
sgillies at frii dot com
http://zcologia.com
