still me
Kumar
kumar at NEWFIELDS.COM
Tue Jul 19 12:31:28 PDT 2005
Check if you have IIS or any other server running. This would block port 80,
which is the default server port listening and sending port. If it is
running Stop the server and try installing Apache.
- kumar
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Tony Denis
Sent: Tuesday, July 19, 2005 3:19 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] still me
thank you for the answer but there's another problem. When i put the ms4w
directly in C drive,and i try to install the apache that's the problem
occur.
(OS 10048)Une seule utilisation de chaque adresse de socket
(protocole/adresse r
Úseau/port) est habituellement autorisÚe. : make_sock: could not bind to
addres
s 0.0.0.0:80
no listening sockets available, shutting down
Unable to open logs
thank you very much for your help
Tony
tdenis at cvrb.qc.ca
More information about the MapServer-users
