still me
Randy James
rjames57 at YAHOO.COM
Tue Jul 19 15:46:33 EDT 2005
Is the network set up properly, it appears that the server does not have a IP
address?
Randy
--- Kumar <kumar at NEWFIELDS.COM> wrote:
> Check if you have IIS or any other server running. This would block port 80,
> which is the default server port listening and sending port. If it is
> running Stop the server and try installing Apache.
> - kumar
> -----Original Message-----
> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
> Behalf Of Tony Denis
> Sent: Tuesday, July 19, 2005 3:19 PM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-USERS] still me
> thank you for the answer but there's another problem. When i put the ms4w
> directly in C drive,and i try to install the apache that's the problem
> occur.
> (OS 10048)Une seule utilisation de chaque adresse de socket
> (protocole/adresse r
> Úseau/port) est habituellement autorisÚe. : make_sock: could not bind to
> addres
> s 0.0.0.0:80
> no listening sockets available, shutting down
> Unable to open logs
> thank you very much for your help
> Tony
> tdenis at cvrb.qc.ca
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
