still me
Carl Burn
burnsy at VIVIDFISH.CO.UK
Wed Jul 20 02:53:37 EDT 2005
think that you might have a conflict on port 80 if you are running a
windows web server. You can get the two to co-exist quite happily, all
you need to do is to edit the httpd.conf file within the ms4w/apache
part of your installation and set it to run on an unoccupied port....eg
8073. If you have a firewall running locally then you may also need to
modify this to cope with the usage of the new port number.
Hope this helps
Carl
Tony Denis wrote:
>thank you for the answer but there's another problem. When i put the ms4w
>directly in C drive,and i try to install the apache that's the problem
>occur.
>(OS 10048)Une seule utilisation de chaque adresse de socket
>(protocole/adresse r
>Úseau/port) est habituellement autorisÚe. : make_sock: could not bind to
>addres
>s 0.0.0.0:80
>no listening sockets available, shutting down
>Unable to open logs
>thank you very much for your help
>Tony
>tdenis at cvrb.qc.ca
Carl Burn
Technical Director
Vividfish Limited.
t: 0845 8900876
w: www.vividfish.co.uk
e: burnsy at vividfish.co.uk
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050720/dfd84f53/burnsy.vcf
