TEMPLATE in map file doesn't run, why?
Daniele Margotti
margottid at COMUNE.LUGO.RA.IT
Wed Jul 20 00:58:27 PDT 2005
A TEMPLATE is an existing .html file that is used by CGI Mapserver as a
"skeleton" page: in this page, there are some fields that Mapserver
substitutes with the image of the map, the scalebar, the reference map,
and other variables (current scale, current extent, and so on).
This TEMPLATE must be defined in the WEB section of the mapfile
(http://mapserver.gis.umn.edu/doc44/mapfile-reference.html#web).
You can also use a TEMPLATE in the CLASS section
(http://mapserver.gis.umn.edu/doc44/mapfile-reference.html#class) or -
if you want the same template for each class of a layer - in the LAYER
section
(http://mapserver.gis.umn.edu/doc44/mapfile-reference.html#layer) of the
mapfile.
In this case, the TEMPLATE (this also must be an existing .html file) is
used by CGI Mapserver when you query the map: the template contains
field that are substituted with vaules of the queried attributes.
In your example mapfile, the TEMPLATE instruction as the following
meaning:
"When you query the map, show results (for this layer) using
http://www.nusvirtual.com as template".
The question is: is this a good template file?
But I suggest you to use a "local" .html file as a template.
Daniele
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of SUBSCRIBE MAPSERVER-USERS Nuri
Sent: Wednesday, July 20, 2005 9:32 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] TEMPLATE in map file doesn't run, why?
I inserted a TEMPLATE instruction in my map file but the link doesn't
run in the map.
Someone could tell me why I'm doing wrong? Thank you.
This is my map file:
MAP
IMAGETYPE PNG
EXTENT 20.000000 18.000000 50.000000 110.000000
SIZE 500 350
SHAPEPATH "data"
IMAGECOLOR 255 180 0
SYMBOLSET "symbols/symbols35.sym"
FONTSET "fonts/fonts.list"
# Start of LAYER DEFINITIONS
LAYER # Capa de raster
NAME mapafig
DATA "raster/figueres.tif"
STATUS DEFAULT
TYPE RASTER
PROCESSING "BANDS=1,2,3"
OFFSITE 0 0 255
END # Fi capa de raster
LAYER
NAME "prova"
TEMPLATE "http://www.nusvirtual.com" <--------
TYPE POINT
CONNECTIONTYPE OGR
CONNECTION "mapa21.ovf"
DATA "mapa21"
LABELITEM "id"
#PROJECTION
# "init=epsg:4326"
#END
CLASS
SYMBOL 'symbols/prova.gif'
#SIZE 6
COLOR 255 0 0
LABEL
SIZE MEDIUM
TYPE BITMAP
COLOR 0 0 0
END
END
END
# End of LAYER DEFINITIONS ------------------------------- END # end
of map file
More information about the MapServer-users
