TEMPLATE in map file doesn't run, why?
N M
mapserver at HOTMAIL.COM
Wed Jul 20 04:42:32 EDT 2005
Hi Daniele,
I understand what you are telling me but the problem is that although I had
an .html page when I execute mapserver, I can't click anywhere in the map,
any clicking zone appears.
I tried using TEMPLATE in LAYER section, in WEB section and in CLASS section
but nothing occurs.
>A TEMPLATE is an existing .html file that is used by CGI Mapserver as a
>"skeleton" page: in this page, there are some fields that Mapserver
>substitutes with the image of the map, the scalebar, the reference map,
>and other variables (current scale, current extent, and so on).
>This TEMPLATE must be defined in the WEB section of the mapfile
>(http://mapserver.gis.umn.edu/doc44/mapfile-reference.html#web).
>You can also use a TEMPLATE in the CLASS section
>(http://mapserver.gis.umn.edu/doc44/mapfile-reference.html#class) or -
>if you want the same template for each class of a layer - in the LAYER
>section
>(http://mapserver.gis.umn.edu/doc44/mapfile-reference.html#layer) of the
>mapfile.
>In this case, the TEMPLATE (this also must be an existing .html file) is
>used by CGI Mapserver when you query the map: the template contains
>field that are substituted with vaules of the queried attributes.
>In your example mapfile, the TEMPLATE instruction as the following
>meaning:
>"When you query the map, show results (for this layer) using
>http://www.nusvirtual.com as template".
>The question is: is this a good template file?
>But I suggest you to use a "local" .html file as a template.
> Daniele
>-----Original Message-----
>From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
>Behalf Of SUBSCRIBE MAPSERVER-USERS Nuri
>Sent: Wednesday, July 20, 2005 9:32 AM
>To: MAPSERVER-USERS at LISTS.UMN.EDU
>Subject: [UMN_MAPSERVER-USERS] TEMPLATE in map file doesn't run, why?
>Hi,
>I inserted a TEMPLATE instruction in my map file but the link doesn't
>run in the map.
>Someone could tell me why I'm doing wrong? Thank you.
>This is my map file:
>MAP
> IMAGETYPE PNG
> EXTENT 20.000000 18.000000 50.000000 110.000000
> SIZE 500 350
> SHAPEPATH "data"
> IMAGECOLOR 255 180 0
> SYMBOLSET "symbols/symbols35.sym"
> FONTSET "fonts/fonts.list"
> # Start of LAYER DEFINITIONS
> LAYER # Capa de raster
> NAME mapafig
> DATA "raster/figueres.tif"
> STATUS DEFAULT
> TYPE RASTER
> PROCESSING "BANDS=1,2,3"
> OFFSITE 0 0 255
> END # Fi capa de raster
> LAYER
> NAME "prova"
> TEMPLATE "http://www.nusvirtual.com" <--------
> TYPE POINT
> CONNECTIONTYPE OGR
> CONNECTION "mapa21.ovf"
> DATA "mapa21"
> LABELITEM "id"
> #PROJECTION
> # "init=epsg:4326"
> #END
> CLASS
> SYMBOL 'symbols/prova.gif'
> #SIZE 6
> COLOR 255 0 0
> LABEL
> SIZE MEDIUM
> TYPE BITMAP
> COLOR 0 0 0
> END
> END
>END
> # End of LAYER DEFINITIONS ------------------------------- END # end
>of map file
_________________________________________________________________
Descubre la descarga digital con MSN Music. Más de medio millón de
canciones. http://music.msn.es/
