[Chameleon] save polygons
Mehdi Kiman oubinny at HOTMAIL.COM
Thu Jul 21 05:04:36 PDT 2005
So, it's really impossible to save ROI objects.
my goal is only to save current user work. I must to resolve this problem
with Oracle database or WFS/WMS or MapInfo files.
Any solutions ?
thanks again
Mehdi
>From: "Bart van den Eijnden" <BEN at Syncera-ITSolutions.NL>
>To: <oubinny at hotmail.com>
>CC: <chameleon at lists.maptools.org>
>Subject: Re: [Chameleon] save polygons
>Date: Thu, 21 Jul 2005 13:50:34 +0200
>Hi,
>what the ExtractWFS widget does is make an extraction from a layer already
>in the map. Assuming you have got eg a provinces layer of your country, you
>can draw an ROI in the map, eg a rectangle, and then the provinces inside
>that rectangle can be saved into GML or a shapefile.
>So this is only extracting existing features, not putting newly digitized
>features into a file or database, which is what I assume you want to do.
>Best regards,
>Bart
>Btw please reply to the whole list.
>Syncera IT Solutions
>Postbus 270
>2600 AG  DELFT
>tel.nr.: 015-7512436
>email: BEN at Syncera-ITSolutions.nl
> >>> "Mehdi Kiman" <oubinny at hotmail.com> 07/21/05 01:45pm >>>
>Hello Bart,
>Can i use  ExtractWFSData widget. Is it possible ton export the XML file
>(GML) directly to MapInfo. Prehaps by using WFS/WMS webservices.
>From chemeleon Help :
>The Extract WFS Data widget allows the user to extract data based on the
>current selected layer and ROI. Currently the following formats are
>supported: GML Shape.
>Thanks a lot
>Mehdi
> >To: <oubinny at hotmail.com>,<chameleon at lists.maptools.org>
> >Date: Thu, 21 Jul 2005 13:12:53 +0200
> >Chameleon is not an edit application, so you will have to add this to
> >Chameleon yourself or hire someone to do it.
> >One option would be getting GML out of the ROI widget (I don't think it
>can
> >do this at the moment), and posting it to a Geoserver WFS which connects
>to
> >Oracle. Optionally you could also probably also use the php_ogr module to
> >transform the GML into Mapinfo format or Oracle Spatial.
> >Quite a difficult task though I think, maybe even something like a week's
> >work.
> >Best regards,
> >Bart
> >Postbus 270
> >2600 AG  DELFT
> > >>> "Mehdi Kiman" <oubinny at hotmail.com> 07/21/05 12:56pm >>>
> >Hello,
> >I use chameleon for making my application.
> >I wish to save my drawing operations in a mapInfo file (.TAB) or in
>Oracle
> >Database.
> >For exemple, i draw a polygon in my map with chameleon ROI widget and
>save
> >it.
> >Can you give me some help please ?
> >Thanks
> >Mehdi
> >_______________________________________________
> >Chameleon mailing list
> >Chameleon at lists.maptools.org
> >http://lists.maptools.org/mailman/listinfo/chameleon
More information about the MapServer-users mailing list
