FW: Re: [Chameleon] save polygons
Mehdi Kiman
oubinny at HOTMAIL.COM
Thu Jul 21 07:53:42 EDT 2005
what the ExtractWFS widget does is make an extraction from a layer already
in the map. Assuming you have got eg a provinces layer of your country, you
can draw an ROI in the map, eg a rectangle, and then the provinces inside
that rectangle can be saved into GML or a shapefile.
So this is only extracting existing features, not putting newly digitized
features into a file or database, which is what I assume you want to do.
Best regards,
Bart
Btw please reply to the whole list.
Bart van den Eijnden
Syncera IT Solutions
Postbus 270
2600 AG DELFT
tel.nr.: 015-7512436
email: BEN at Syncera-ITSolutions.nl
> >>> "Mehdi Kiman" <oubinny at hotmail.com> 07/21/05 01:45pm >>>
>Hello Bart,
>Can i use ExtractWFSData widget. Is it possible ton export the XML file
>(GML) directly to MapInfo. Prehaps by using WFS/WMS webservices.
>From chemeleon Help :
>The Extract WFS Data widget allows the user to extract data based on the
>current selected layer and ROI. Currently the following formats are
>supported: GML Shape.
>Thanks a lot
>Mehdi
> >From: "Bart van den Eijnden" <BEN at Syncera-ITSolutions.NL>
> >To: <oubinny at hotmail.com>,<chameleon at lists.maptools.org>
> >Subject: Re: [Chameleon] save polygons
> >Date: Thu, 21 Jul 2005 13:12:53 +0200
> >Chameleon is not an edit application, so you will have to add this to
> >Chameleon yourself or hire someone to do it.
> >One option would be getting GML out of the ROI widget (I don't think it
>can
> >do this at the moment), and posting it to a Geoserver WFS which connects
>to
> >Oracle. Optionally you could also probably also use the php_ogr module to
> >transform the GML into Mapinfo format or Oracle Spatial.
> >Quite a difficult task though I think, maybe even something like a week's
> >work.
> >Best regards,
> >Bart
> >Postbus 270
> >2600 AG DELFT
> > >>> "Mehdi Kiman" <oubinny at hotmail.com> 07/21/05 12:56pm >>>
> >Hello,
> >I use chameleon for making my application.
> >I wish to save my drawing operations in a mapInfo file (.TAB) or in
>Oracle
> >Database.
> >For exemple, i draw a polygon in my map with chameleon ROI widget and
>save
> >it.
> >Can you give me some help please ?
> >Thanks
> >Mehdi
> >_______________________________________________
> >Chameleon mailing list
> >Chameleon at lists.maptools.org
> >http://lists.maptools.org/mailman/listinfo/chameleon
