Virtual Spatial Data through OCI
Bart van den Eijnden
BEN at SYNCERA-ITSOLUTIONS.NL
Thu Jul 21 07:07:49 PDT 2005
Frank,
adding it to the ALL_SDO_GEOM_METADATA table with some dummy values did the trick. Altough ofcourse it is not a Spatial table in the Oracle spatial terms, just an X Y column type of table, but anyway, it works.
Thanks.
Best regards,
Bart
Syncera IT Solutions
Postbus 270
2600 AG DELFT
tel.nr.: 015-7512436
email: BEN at Syncera-ITSolutions.nl
>>> Frank Warmerdam <fwarmerdam at GMAIL.COM> 07/21/05 03:54pm >>>
On 7/21/05, Bart van den Eijnden <BEN at syncera-itsolutions.nl> wrote:
> Hi list,
> probably a question for Frank.
> I am trying to use an Oracle X Y column table through virtual spatial data. I compiled GDAL against the Oracle client. I can access it through ODBC without any problems.
> When doing an ogrinfo on the ovf file I created, I get:
> D:\ms4w\apps\stragisweb\htdocs\sites\westland\data>ogrinfo adr4all.ovf
> ERROR 4: Update access not supported for VRT datasources.
> ERROR 1: Failed to find layer 'ADR5_ADRESCYCLUS' on datasource 'OCI:CAB/CAB at 10.1
> 5.7.7:1521/ONTW'.
Bart,
You might want to do an ogrinfo request against the datasource
to get a list of all the recognised layers.
eg.
ogrinfo OCI:CAB/CAB at 10.15.7.7:1521/ONTW
If you don't provide an explicit list of tables to treat as layers,
OGR is supposed to scan ALL_SDO_GEOM_METADATA for
tables to expose. Perhaps your ADR5_ADRESCYCLUS table
is not in ALL_SDO_GEOM_METADATA? Or perhap it is
not being recognised for some other reason? An alternative
would be to explicitly list it as a table you want exposed as
a layer:
ogrinfo OCI:CAB/CAB at 10.15.7.7:1521/ONTW,ADR5_ADRESCYCLUS
I hope this helps.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
More information about the MapServer-users
