Need some help with mapserver 4.6
Jeff Portwine
jdport at VERITIME.COM
Thu Jul 21 06:09:39 PDT 2005
I'm having a few problems with my mapserver 4.6 upgrade.
In my application, I add some geocoded points onto the map. The points are
marked simply with a colored circle on top of a white circle... so for
example you get a blue dot with a white outline. In 4.4.1, this works
fine. In v4.6, it shows the top circle offset from the bottome circle, so
that the edge of the top circle on one side of the circle is tangent with
the edge of the bottom circle. I can't really imagine why this happens.
Here is my mapserv -v for both versions:
MapServer version 4.4.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER INPUT=EPPL7
INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG
MapServer version 4.6.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=SVG SUPPORTS=FREETYPE INPUT=EPPL7 INPUT=JPEG INPUT=SHAPEFILE
This brings me to my next problem. I originally installed mapserver in
debian using a debian package. So far as I am aware, v.4.6 isn't available
to apt-get yet so I tried to compile it myself. My original included
support for gdal and ogr, which I think I should have even if i'm not sure
whether or not I need it... I tried adding those just in case that was the
reason for my misaligned circle markers. I did an apt-get libgdal1 and
libgdal1-dev and added the --with-gdal --with-ogr options to my configure
and I get a bunch of errors that look like this:
: undefined reference to `OGRSpatialReference::IsLocal(void) const'
./libmap.a(mapogr.o)(.text+0x7f): In function
`msOGRSpatialRef2ProjectionObj(OGRSpatialReference *, projectionObj *,
int)':
: undefined reference to `OGRSpatialReference::exportToProj4(char **) const'
./libmap.a(mapogr.o)(.text+0x132): In function `msOGCWKT2ProjectionObj':
: undefined reference to `OGRSpatialReference::OGRSpatialReference(char
const *)'
Can anybody help me out with these two issues?
I would just stick with 4.4.1 but I need to be able to do a query by point
on points that have been added to my map in mapscript and as I understand
it, this isn't possible in 4.4.1.
Thanks,
Jeff
More information about the MapServer-users
