Problems with gdal
Frederico Lucca fredlucca at GMAIL.COM
Thu Jul 21 13:05:47 PDT 2005
On 7/21/05, Frank Warmerdam <fwarmerdam at gmail.com> wrote:
> On 7/21/05, Frederico Lucca <fredlucca at gmail.com> wrote:
> > Hello Frank,
> > Let me see, if a use a shape file, without OGR, can I have a mutex?
> > I use a Mapinfo file, but if I can translate this to shape and have a
> > mutex, I can do this.
> > I will test...
> Frederico,
> I believe the direct shapefile support in MapServer is threadsafe, so
> if you can easily translate to shapefiles that is likely prudent.
> > But if you can do a mutex for OGR (and you think that it's important)
> > I can test in my enviroment too.
> Well, it needs to be done eventually. There is already an open bug
> report on the issue, I believe.  But I'm happy enough to leave it for
> another time.
> Best regards,
Hello Frank,
Well, I translate some TABs to SHPs using org2ogr.
Then I return to my tests and loopings, and I get this error.
C [libpthread.so.0+0x6a12] __pthread_mutex_lock+0x12
What can I do now?
I call a jsp page which create a unique map, I call this application
from another with a looping  - for 1 to 100. Then, I put 3 or 4 of
this applications running at same time. And I get the error. When I
was using TABs I get the error (with gdal) with 2 applications running
at same time.
Thanks in advance.
Best Regards,
Fred
"Everything under the sun is in tune
But the sun is eclipsed by the moon"
More information about the MapServer-users mailing list
