Problems with gdal
Frank Warmerdam
fwarmerdam at GMAIL.COM
Thu Jul 21 16:31:39 EDT 2005
On 7/21/05, Frederico Lucca <fredlucca at gmail.com> wrote:
> Hello Frank,
> Well, I translate some TABs to SHPs using org2ogr.
> Then I return to my tests and loopings, and I get this error.
> C [libpthread.so.0+0x6a12] __pthread_mutex_lock+0x12
> What can I do now?
> I call a jsp page which create a unique map, I call this application
> from another with a looping - for 1 to 100. Then, I put 3 or 4 of
> this applications running at same time. And I get the error. When I
> was using TABs I get the error (with gdal) with 2 applications running
> at same time.
Frederico,
This is using mapserver and shapefiles, without using CONNECTIONTYPE
OGR, right?
I am not sure why you are running into problems. It isn't a configuration
I can easily reproduce myself.
Sorry,
and watch the world go round - Rush | Geospatial Programmer for Rent
