Can't load WMS raster layer using Python Mapscript
Sean Gillies
sgillies at FRII.COM
Fri Jul 22 08:22:49 PDT 2005
On Jul 22, 2005, at 8:48 AM, William Hudspeth wrote:
> I am using Mapserver 4.4.1 on Fedora Core 3 and am having problems
> getting a WMS Raster Layer to display in my map. The error I am getting
> is:
> Traceback (most recent call last):
> File "/var/www/cgi-bin/reason/mapmodule4.py", line 675, in build_map
> self.map_image=self.currentMap.draw()
> File "/usr/local/lib/python2.4/site-packages/mapscript.py", line
> 1419,
> in draw
> def draw(*args): return _mapscript.mapObj_draw(*args)
> MapServerError: msRASTERLayerOpen(): General error message. Attempt to
> open a RASTER layer, but this is only supported after a raster query.
> In my map file, the WEB element looks like this:
> WEB
> IMAGEPATH "/var/www/html/tmp"
> IMAGEURL "/tmp/"
> METADA
> "wms_title" "REASoN WebMap Interface"
> "wms_onlineresource" "http://falstaff.unm.edu/cgi-bin/mapserv?
> map=reason/reason.map&"
> "wms_srs" "EPSG:4326"
> END #end metadata
> END #end web
> and, the layer element looks like this:
> LAYER
> NAME "global_mosaic"
> TYPE RASTER
> STATUS ON
> CONNECTION "http://onearth.jpl.nasa.gov/wms.cgi?"
> CONNECTIONTYPE WMS
> METADATA
> wms_abstract "JPL Landsat7 ETM+ Global Mosaic WMS"
> wms_keywordlist "Global Mosaic, JPL, Landsat7 ETM+, WMS"
> wms_opaque "0"
> wms_srs "EPSG:4326"
> wms_name "global_mosaic"
> wms_title "WMS Global Mosaic, pan sharpened"
> wms_formatlist "image/png,image/jpeg"
> wms_format "image/jpeg"
> END #end metadata
> PROJECTION
> "init=epsg:4326"
> END
> END #end layer
> I would appreciate any insight on the error message I am receiving.
> Thank you,
> Bill
Bill, this appears to be a bug in 4.4.1 that was fixed (IIRC) in 4.4.2
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1118
cheers,
Sean
Sean Gillies
sgillies at frii dot com
http://zcologia.com
More information about the MapServer-users
