hyperlink in a map [solved]
Dylan Beaudette
dylan at IICI.NO-IP.ORG
Fri Jul 22 12:17:15 EDT 2005
Bob and Jim,
Thanks again for the help. It turns out that I was using a link to the
image map file, and this changes to my mapserver .MAP file had no
effect. The CLASSITEM keyword solved the problem!
Thanks!
On Jul 21, 2005, at 9:56 PM, Bob Bruce - Programmer wrote:
> Dylan:
> I see that Jim has already replied to your email and I believe that
> he has your answer.
> I was glad to have been of some help to you, hopefully I will be able
> to get my changes for point symbols implemented in the release of the
> MapServer soon and vector symbols will be available for imagemapping
> just like polygons are at the present.
> Bob Bruce
> http://www.hwps.ca
> -----Original Message-----
> From: Dylan Beaudette [mailto:dylan at iici.no-ip.org]
> Sent: 21-Jul-05 3:35 PM
> To: Bob Bruce
> Cc: MAPSERVER-USERS at lists.umn.edu
> Subject: Re: [UMN_MAPSERVER-USERS] hyperlink in a map
> On Wednesday 20 July 2005 10:22 am, Bob Bruce wrote:
>> Nuri:
>> I use the imagemap feature of MapServer to do this. Right now
>> there
>> is only support for vector symbols and the 'out of the box' support
>> only
>> allows for a single URL to be referenced for all symbols. I have made
>> my
>> own MapServer modifications (which I still need to upload to the
>> website)
>> that allow for individual symbols to be mapped uniquely, if you are
>> into
>> building MapServer then I can provide those changes to you.
> Bob,
> Thanks for posting this very helpful link.
> I have successfully replicated the example on the Wiki. However, is
> there any
> way to manipulate the attribute that gets saved to the <MAP>
> definition? i.e.
> is it possible to write a specific attribute from my vector data to
> the <MAP>
> definition, as opposed to the default numbers (0,1,2...) ?
> thanks!
> Dylan Beaudette
> Soils and Biogeochemistry Graduate Group
> University of California at Davis
> 530.754.7341
Dylan Beaudette
530.754.7341
