What does compile with "--with-httpd" do?
Frank Warmerdam
fwarmerdam at GMAIL.COM
Tue Jul 26 10:29:32 EDT 2005
On 7/25/05, Adam W <adam at jamradar.com> wrote:
> I searched the mailing list and documentation, but could't find what
> compiling mapserver with "--with-httpd" lets you do.
> What options do I get if I compile with "--with-httpd"?
> What extra things does compiling with "--with-httpd" do?
Adam,
Looking through configure.in it seems that this option is used to determine
if the server is Apache 2.x so that later on the --enable-debug switch
can decide if extra work needs to be done to make stderr error logging
"non-blocking".
I'm not sure what bad things might happen if you don't make stderr
logging non-blocking on Apache 2 though.
If you aren't using --enable-debug or Apache 2 it shouldn't matter
wether you use --with-httpd or not.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
