Labels using shape index
Steve Lime
steve.lime at DNR.STATE.MN.US
Tue Jul 26 15:22:31 EDT 2005
So you want to label with the result number NOT the the shape number- big difference.
Then looping as you suggest is the best option but using the result counter as the label
value not the shape id.
Steve
>>> Eric Shuman <erics at AMERI-TITLE.COM> 07/26/05 2:12 PM >>>
Well the ID column would have to be for all the shapes in the shapefile.
The query only returns 50 or so results. If I used the ID at that point the
numbering would not be sequential.
I'm thinking the best option at this point would be to create a temporary
annotation layer by looping through the results of the query and getting the
label point of the polygon shapes and drawing them on the map with the
ShapeID.
