Installation
Till Adams
adams at TERRESTRIS.DE
Wed Jul 27 10:01:09 EDT 2005
Geraint Lee wrote:
> Hey all,
> I've been trying to install mapserver for several days now, coming
> accross a number of installation problems (with other programs like gd,
> jpeg-2b...) which i've overcome... now i'm stuck on mapserver.
> gd, jpeg, freetype2, libiconv and libpng are all installed on the server
> (FreeBSD 4.11)... anyway, here's the output from:
> ./configure --with-png=/usr/local --with-jpeg=/usr/local
> --with-freetype=/usr/local --without-xpm --with-libiconv=/usr/local
> --with-gd=/usr/local
> configure: checking where FreeType 2.x is installed...
> using libfreetype from -L/usr/local/lib -Wl,--rpath
> -Wl,/usr/local/lib -lfreetype -lz
> checking for FT_Init_FreeType in -lfreetype... no
> using libfreetype -L/usr/local/lib -Wl,--rpath
> -Wl,/usr/local/lib -lfreetype -lz from system libs.
> configure: checking where Zlib is installed...
> checking for zlibVersion in -lz... yes
> using libz from system libs.
> configure: checking where PNG is installed...
> using libpng from -L/usr/local/lib64 -lpng
> configure: checking whether we should include JPEG support...
> using libjpeg from system -L/usr/local/lib64 -ljpeg
> configure: checking where libiconv is installed...
> checking for iconv_open in -lc... no
> checking for libiconv_open in -liconv... yes
> using libiconv from -L/usr/local/lib64 -liconv
> libiconv found. Enabling internationalization (-DUSE_ICONV)
> configure: checking for GD 2.0.12 or higher...
> checking for gdImageSetAntiAliased in -lgd... no
> configure: checking whether GD needs libiconv...
> configure: error: Could not find gd.h or libgd.a/libgd.so in
> /usr/local. Make sure GD 2.0.12 or higher is compiled before calling
> configure. You may also get this error if you didn't specify the
> appropriate location for one of GD's dependencies (freetype, libpng,
> libjpeg or libiconv).
> all of those files exist in /usr/local/lib and /local - does anyone have
> any suggestions at all as to what the problem may be.
> Thanks
> Geraint
Geraint,
which OS (Debian Linux, Suse, edHat, etc.) do you use?
We have several step-to-step descriptions (sorry for not making them
open to everybody till now) for Win, Suse 9.x, Debian Woody and Sarge,
Mandrake, RedHat and FreeBSD. I may send you the appropriate for you.
Fiorst of all - the easiest may be just to try a
# /sbin/ldconfig /usr/local/lib -v
and
# /sbin/ldconfig /local -v
to make the libs known to your system. Also add these pathes to the file
/etc/ld.so.config, so you don't have to do this every time you reboot.
Greetings from Bonn, Till
Mit freundlichen Grüssen aus Bonn,
Till Adams
* released: AmeiN! ArcMap-Export-2-UMN *
* LiveLinux 'WebGIS on CD' *
* http://www.terrestris.de *
Dipl. Geogr. Till Adams
terrestris, H. Paulsen& T. Adams GbR
Siemensstr. 8 * 53121 Bonn
Tel.: 0228 962 899 52 * Fax.: 0228 962 899 57
info at terrestris.de * http://www.terrestris.de
