Join? Query? Select?
Daniele Margotti
margottid at COMUNE.LUGO.RA.IT
Wed Jul 27 13:12:05 EDT 2005
Hi list,
I have a point layer, based on a shapefile.
I also have many .DBF files, which are reduced sets of the original .DBF of
my shapefile (i.e., I have only one field, "ID", that corresponds to
the "ID" field of the original shapefile, and only some records - not ALL
of them).
Now, the problem:
When I browse the map, I want to see ONLY the points that are listed in
my "reduced" .DBF (or, alternatively, see them in a different color -
defining a CLASS item).
Since I use CGI Mapserver, I also want to define a variable (%dbf%) that
should be inserted in the mapfile, so I can modify it to change the view of
my map (without modify my mapfile).
Is it possible?
What do I have to add to the mapfile?
Thank you,
Daniele
