artifacts at tiled image borders
    Dylan Beaudette
    dylan at IICI.NO-IP.ORG
    Wed Jul 27 13:56:11 PDT 2005
Greetings,
I have been doing some research on better ways to store my aerial imagery, so
that I can keep a higher resolution version of my source files. Until now I
have been downsampling USGS DOQQ images from 1 meter resolution to 10 meters,
saving the result as a geoTiff. With overviews, these file are about 1.5 mb
per quarter quad. A shapefile tile index is used to render the images in
Mapserver.
Last night I re-created a section of the tiled dataset in JPEG format at 3
meter resolution. I am much happier with the resulting increase in detail,
however I am now noticing some strange artifacts showing up at the "seams" of
the tile index.
here is an example of what I am talking about:
http://169.237.35.250/~dylan/temp/mapserver/bad_edges.jpg
the source data do not appear to have these type of "rough edges":
http://169.237.35.250/~dylan/temp/mapserver/original_clean_edges.jpg
I am using the OFFSITE operator in my map file to ignore pixels with an RGB
value of '0 0 0'.
Does anyone have any idea what could be causing these rough looking seams at
the tileindex boundaries?
thanks in advance!
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
More information about the MapServer-users
