artifacts at tiled image borders
Frank Warmerdam
fwarmerdam at GMAIL.COM
Wed Jul 27 14:23:22 PDT 2005
On 7/27/05, Dylan Beaudette <dylan at iici.no-ip.org> wrote:
> Greetings,
> I have been doing some research on better ways to store my aerial imagery, so
> that I can keep a higher resolution version of my source files. Until now I
> have been downsampling USGS DOQQ images from 1 meter resolution to 10 meters,
> saving the result as a geoTiff. With overviews, these file are about 1.5 mb
> per quarter quad. A shapefile tile index is used to render the images in
> Mapserver.
> Last night I re-created a section of the tiled dataset in JPEG format at 3
> meter resolution. I am much happier with the resulting increase in detail,
> however I am now noticing some strange artifacts showing up at the "seams" of
> the tile index.
> here is an example of what I am talking about:
> http://169.237.35.250/~dylan/temp/mapserver/bad_edges.jpg
> the source data do not appear to have these type of "rough edges":
> http://169.237.35.250/~dylan/temp/mapserver/original_clean_edges.jpg
> I am using the OFFSITE operator in my map file to ignore pixels with an RGB
> value of '0 0 0'.
> Does anyone have any idea what could be causing these rough looking seams at
> the tileindex boundaries?
Dylan,
The problem is that jpeg is a lossy format, and along the boundaries
areas that should be black are in fact just very slightly non-black and
so are not recognised as offsite.
This will occur to varying degrees with any lossy format like jpeg,
ecw, jpeg2000 and mrsid.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
More information about the MapServer-users
