weired zooming problem
Shashi Gireddy
gireddy at GMAIL.COM
Thu Jul 28 02:32:21 EDT 2005
I have a weired zooming problem. I have two shape files with same image extent.
1. Roads with surface type, length, hwy etc.. for south texas (LINES)
2. Reference markers for the same roads (POINTS)
I am creating two layers for each of them. the problem is
It works If I zoom out or Pan (If I click on the upper left cornor Pan
Doesn't work)
It doesn't work If I click on zoom in (it works If I zoom out once and
zoom in once, but after second click it gives me a blank map, but it
still showing the legent, and scale)
IF I use only surface type (LINES) it works perfect
but If I use only reference markers It does't work(behaves as above)
I guess It is the probmem with the extent of Reference Markers , i
tried to change but didn't help me (I used ArcView to know the Extent)
here are my extent values EXTENT -98.64 29.32 -96.35 27.15
I know there is an other way of representation, but I don't know how
to convert or how to check tht in arcview.
can anybody help me please.
thanks in advance.
shashi.
Shashi Kiran Reddy. Gireddy,
Graduate Assistant,
CBER, University of Alabama.
http://www.cs.ua.edu/shashi
Cell: 205-239-6655
